About the S5800 Command References
HomeSupportSwitchesH3C S5820X Switch SeriesReference GuidesCommand ReferencesH3C S5820X[S5800] Series Ethernet Switches Command References-Release 1110-6W103About the S5800 Command References
Click the links on the right to download all the command references.
About the H3C S5800&S5820X Command References
The H3C S5800&S5820X command references are part of the H3C S5800&S5820X documentation set. They describe the commands and command syntax options available for the H3C S5800&S5820X Series Ethernet Switches Release 1110. The H3C S5800&S5820X documentation set includes 11 command references:
Command Reference
Content
Fundamentals Command Reference
Covers the commands for logging in to and setting up an S5800&S5820X switch. This command reference includes:
l      CLI
l      Logging In to the Switch
l      FTP and TFTP
l      File Management
l      Configuration File Management
l      Upgrading Software
l      Device Management
l      Automatic Configuration
IRF Command Reference
Covers the commands for configuring the H3C proprietary Intelligent Resilient Framework (IRF) technology features. It covers planning the switch roles in the IRF virtual device, connecting the IRF link, and detecting and maintaining the IRF virtual device.
Layer 2 – LAN Switching Command Reference
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes:
l      Ethernet Port
l      Loopback Interface and Null Interface
l      MAC Address Table
l      Ethernet Link Aggregation
l      Port Isolation
l      MSTP
l      BPDU Tunneling
l      VLAN
l      GVRP
l      QinQ
l      VLAN Mapping
l      LLDP
l      Service Loopback Group
Layer 3 – IP Services Command Reference
Covers the commands for configuring IP addresses, adjusting IP parameters, configuring ARP, DNS, and UDP Helper, and implementing interoperation between IPv4 and IPv6. This command reference includes:
l      ARP
l      IP Addressing
l      DHCP
l      DNS
l      IP Performance Optimization
l      UDP Helper
l      IPv6 Basics
l      DHCPv6
l      Tunneling
Layer 3 – IP Routing Command Reference
Covers the routing configuration commands. This command reference includes:
l      IP Routing Basics
l      Static Routing
l      RIP
l      OSPF
l      IS-IS
l      BGP
l      IPv6 Static Routing
l      RIPng
l      OSPFv3
l      IPv6 IS-IS
l      IPv6 BGP
l      Route Policy
l      MCE
l      Policy Routing
IP Multicast Command Reference
Covers the commands for configuring Layer 2 and Layer 3 multicast services. This command reference includes:
l      IGMP Snooping
l      Multicast VLAN
l      Multicast Routing and Forwarding
l      IGMP
l      PIM
l      MSDP
l      MBGP
l      MLD Snooping
l      IPv6 Multicast VLAN
l      IPv6 Multicast Routing and Forwarding
l      MLD
l      IPv6 PIM
l      IPv6 MBGP
ACL and QoS Command Reference
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS or hierarchical QoS (HQoS) technologies to improve network performance and network use efficiency. This command reference includes:
l      ACL
l      QoS
Security Command Reference
Covers security feature commands. Available security features include identity authentication (AAA), access security (802.1X, MAC authentication, and portal), secure management (SSH), SSL, and attack protection (IP source guard, ARP attack protection, and URPF). This command reference includes:
l      AAA
l      802.1X
l      MAC Authentication
l      Portal
l      Port Security
l      User Profile
l      HABP
l      Public Key
l      PKI
l      SSH2.0
l      SSL
l      IP Source Guard
l      ARP Attack Protection
l      URPF
l      MFF
High Availability Command Reference
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes:
l      Ethernet OAM
l      CFD
l      DLDP
l      RRPP
l      Smart Link
l      Monitor Link
l      VRRP
l      BFD
l      Track
Network Management and Monitoring Command Reference
Covers the commands that help you manage and monitor your network, for example, manage system events, collect traffic statistics, sample packets, assess network performance, synchronize the clock for all devices with the clock in the network, supply power for attached devices by using PoE, perform cluster management for switches, and test network connectivity. This command reference includes:
l      System Maintenance and Debugging
l      NQA
l      NTP
l      IPC
l      PoE
l      SNMP
l      RMON
l      Cluster Management
l      Sampler
l      Mirroring
l      NetStream
l      IPv6 NetStream
l      sFlow
l      Information Center
OAA Command Reference
Covers the commands for logging in to the H3C open application platform (OAP) card connected to your switch and resetting the operating system of the OAP card. H3C OAP cards use the open service architecture design, and enable you to provide custom services. This command reference includes:
l      OAP Card
l      ACFP
l      ACSEI
